Old 06-13-2012, 06:50 PM   #1
CNMDESIGN.COM
sub floor seam, tile overlap
Putting down 18in tile, but in one spot it only overlaps the seam in sub floor by 2in.
Will this be a problem?
Thanks Craig
20yr retired Combat Vet. 17yr Master Weaver with the Longaberger Co. Owner of CNM Design
CNM Design is offline   Reply With Quote
Old 06-13-2012, 07:06 PM   #2
Not even close to enough info.
18" tiles will require a near perfectly flat floor.
What do you have now for a subfloor and what are the widths and spans of the floor joist.
Are you trying to lay this tile directly over a plywood subfloor?
Old 06-13-2012, 07:59 PM   #3
CNMDESIGN.COM
1/4in Hardibaker over 5/8 ex plywood over 1x12 on a 45 on 2x10s at 16oc
Old 06-13-2012, 08:01 PM   #4
Was it subfloor rated plywood? Or just CDX?
The seams in the tile board were suppost to have webed tile tape and thinset over them as you were tiling.
Old 06-13-2012, 08:10 PM   #5
Super Moderator
It should not matter if the hardi backer seam fall near the seam of the plywood sub floor--or the tile near a seam in the backer board---
JetSwet (06-13-2012)
Old 06-13-2012, 08:16 PM   #6
CNMDESIGN.COM
Thanks Mike
I all so plan to tape them. Just doing the layout now.
Old 06-13-2012, 08:24 PM   #7
Just need to make sure it's subfloor rated subflooring. CDX is not going to cut it.
Subfloor rated means there's no voids in the plys and ext. glue.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Covering Kitchen Wall Tile ryanb4614 Tiling, ceramics, marble 6 12-03-2011 11:34 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
