Sub-floor Prep For Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 05:39 PM   #1
sub-floor prep for ceramic tile
Hi,
In my kitchen I have 5/8" ply over 1/2" on 2x8x13' at 16"OC.
I pulled up the 1/4" ply with stick on tiles and the staples were left behind, as well as some kind of thinset like material. I don't know if there was once a ceramic tile floor on the plywood subfloor, or if they put the 1/4" ply on the "thinset" stuff intentionally. The floor looks good but there are bare spots in the "thinset" covering. Maybe it was used as a floor leveler, but I can't see that the subfloor would have needed it.
Can I bang in the staples with a hammer (would be very hard to remove) and then feather in the bare spots with something (what?) and then use thinset (what kind?) to attach 1/4" backerboard.
(Note: I was going to cover the whole room in backerboard before I set cabinets and then tile around the cabinets. Are there any issues with setting my base cabinets on the backerboard?)
Thanks so much.
Rob
moondog111 is offline   Reply With Quote
Old 10-30-2008, 06:19 PM   #2
Floorwizard's Avatar
Portland based cement
None that I can think of.
Floorwizard is offline   Reply With Quote
Old 10-30-2008, 08:04 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 212
Hi Rob,
I was just in Alex a few weeks ago.
That cement product was probably for leveling as you stated. Hammer down the staples then check the floor for flatness using a long straight edge. When I say long I mean something close or over 10 ft. You may need more tweeking? The spec for floor flatness is; within 1/4" in 10 ft. AND 1/16" in 12" of the required plane.
The thinset required to install the backer isn't that important, depends on the brand of backer board you buy. Most want you to use modified thinset under the board, as well as to install the tiles.
Do I understand that your 2x8 joists are spanned 13 ft.? Did you actually measure that? If not, please measure the exact distance from face to face of the supports. Also see if they are stamped with a species and grade.
Jaz
Old 10-30-2008, 08:48 PM   #4
Thanks Jaz,
I will post tomorrow, when I get off work, with exact span, species, and grade.
It's okay then to use any portland based floor leveler with what's there now? I see alot of posts about Detra... I like the idea of saving 1/8" in hieght. Should I use it instead of 1/4" durock and will it be okay to do the whole floor and put cabinets on?
Ciao,
Rob
Old 10-30-2008, 10:14 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 212
Any patching must be Portland based. Of course be sure it's made for the substrate you have. May need to mix with an additive?
Ditra is much better than any CBU. It's more expensive too....but?
No need to cover the floor 100%, you can outline the cabinets and just go a little past them. They will need to be shimmed up to get them level anyway.
ciao,
Jaz
Old 10-31-2008, 10:30 AM   #6
Thanks Jaz,
The stamp on the joists reads:
PLIB CONST
73 WCH
WCLB RULES
Doesn't mean anything to me ....hopefully that gives you the species and grade.
They are 2x8 spaning 12'-0" @16" OC.
Again it's 5/8" plywood over 1/2" plywood.
Thanks again.
Rob
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
