To Sub-Floor Or Not To Sub-Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 09:18 PM   #1
To Sub-Floor or not to Sub-Floor
So I am new to the DIY scene, but I am looking to lay laminate in the basement of my new house. I have heard conflicting answers as to whether there should be a sub-floor installed on top of the concrete basement floor. Some say a strong foam-like vapour barrier is sufficient, but others say that an actual sub-floor is best. It is only a 15 year old house with no indication of moisture leaking in through the foundation.
The other question I have is about acclimatizing the laminate to the house before installing. The supplier stated that their stock is stored in a climate and humidity controlled warehouse so this step will not be necessary.
Any and all help would be greatly appreciated.
Thanks!!
klake24 is offline   Reply With Quote
Old 07-10-2011, 10:00 PM   #2
Architect / Carpenter
The foam + vapor barrier is fine under the floating laminate flooring over a concrete slab. Adding a wood sub-floor on sleepers would give the floor a little more cushion than the hard concrete, but it's not necessary. I've installed a several laminate floors over concrete without a sub-floor and they have performed fine.
Acclimatizing the material isn't a big issue with laminate, especially if the supplier keeps it in an environment similar to your basement. Plus, because the laminate is a floating floor, there are no nails or glue to cause problems if it does expand or contract slightly - just be sure to leave the proper expansion gaps at the edges of the room.
carpitect is offline   Reply With Quote
Old 07-10-2011, 10:02 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
I would disagree with one thing. Plywood on concrete is never a good idea.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-10-2011, 10:57 PM   #4
Agreed rusty baker!
If the sub-floor is desired it should be installed over sleepers or joists with a ventilated air space to prevent moisture from the concrete deteriorating the plywood and the growth of mold.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
