Sub Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 03:54 AM   #1
Sub Floor
I would like to replace the actual sub-floor in at least my bathroom and the kitchen. I need more info on the structural implications of doing this. From a "structural" standpoint, should I swap-out panel for panel as I move or just take it all out at once and replace it ~ does it matte either way?
Thanks,
Kevin
kevsprojects is offline   Reply With Quote
Old 07-10-2011, 06:38 AM   #2
DIY staff
Rewards Points: 7,174
I just remove it all---then replace it. That gives you the option of sistering in joists--replacing plumbing and whatever else needs doing without the sub floor in the way.
BigJim (07-10-2011)
Old 07-10-2011, 08:00 AM   #3
Great! I was hoping that would be the case. I am researching cut methods. I thought maybe a trim saw or close cut saw of sorts. Have any recommendations on that?
Old 07-10-2011, 08:29 AM   #4
Full time DIY
Get a toe kick or electric flush cut saw.
G-Mo is offline   Reply With Quote
Old 07-11-2011, 07:47 PM   #5
DIY staff
If the new sub floor will be as thick or thicker than the old one---leave it 1 1/2" out from the walls.
That is easier --faster---and gives you a surface to screw blocking into to support the new subfloor.
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
