Stuck Finish Nail - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 08:20 PM   #1
stuck finish nail
Hi
I have a few finish nails on the wood trim of my staircase that are sticking out a few mm. I have tried to nail it in with a nail set, but will not go in any further; and I have tried using a plier to pull out nail but unable to get a hold since only 1-2 mm sticking out
I do not think it is sticking out enough to use hack saw, any other ideas
It is a pick annoying to be stepping on these will going up stairs
thanks
Peter
pjlee74 is offline   Reply With Quote
Old 05-31-2010, 08:44 PM   #2
Rewards Points: 530
Painted or stained?
Old 05-31-2010, 08:51 PM   #3
These are absolutely invaluable-you don't cut off the nail, you just use these to pry it out
http://mcdougallshomehardwareoban.co...g%20pliers.jpg
You can also use a small grinding wheel mounted in an arbor and chucked in your electric drill to grind the nail flush with the stair surface, but this method requires some care.
Or, use a nail set to bend over the nail and force the head under the wood surface but the bending over has to be parallel with the wood grain.
Old 05-31-2010, 08:54 PM   #4
Hi
thanks
Peter
I would just grind them down with a rotary tool (aka dremel). You can use one of the grinding stones and a heavy duty cutting wheel. If you don't own one and don't want to shell out $80+ get the black and decker rotary tool. It runs for about $25 on walmart.com
campos202 is offline   Reply With Quote
Old 05-31-2010, 10:36 PM   #5
thanks guys,
will try the tips.. sounds great though
peter
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
buying a nail gun with compressor Dave777 Tools 9 11-28-2011 12:37 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
clipped FINISH vs. FRAMING nail amakarevic Building & Construction 4 04-25-2008 04:46 PM
