Old 04-22-2007, 01:58 PM   #1
Stripping rubber padding off a parquet floor
Hi All ! Here I am -the absolute rank beginner.
I am removing the carpet and foam rubber padding to re-do a parquet floor. The Carpet, as well as 90% of the foam rubber padding came up easily.
But there are these spots in high traffic areas where the foam rubber padding, (which was under the carpet) has been pounded down so its like hardened glue. I was gently using a paint scraper, but I am afraid I'll damage the parquet floor.
Any suggestions ?
nubee is offline   Reply With Quote
Old 04-22-2007, 02:08 PM   #2
Floorwizard's Avatar
a bit of damage is not too bad because you are gonna sand and refinish anyway.
see if a putty knife will scoop it up.
Floorwizard is offline   Reply With Quote
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 02:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
