Old 04-25-2010, 12:15 PM   #1
Post
Stretching carpet
I had to take up the carpet from the tack strips in a 12' x 14' room in order to roll back for termite treatment in a finished breezeway. Now I need to restretch and reattach the carpet. From searching various sites and this forum, it seems that a kicker is only used to attach the carpet in one corner for a starting point. After that a stretcher is used. I have been unable to find any details on methods, techniques and pattern to follow. Please reply only if you have experience doing this.
10ecEd is offline   Reply With Quote
Old 04-25-2010, 12:23 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Stretching carpet
http://www.carpet-rug.org/pdf_word_docs/105.pdf There is a diagram in this that will show you step by step how to stretch it.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 04-25-2010, 02:52 PM   #3
Thumbs up
Stretching carpet
Thank you, Rusty. This is exactly what I am seeking. I had hoped to do the job today but had been advised by several others to just get a kicker. The rental shop also had a stretcher but the clerk did not know anything about laying carpet and thought that it was only used for large rooms. So it will be next weekend before I get back to this. Stay tuned for the results.
Old 05-02-2010, 04:49 PM   #4
Thumbs up
Stretching carpet
Rented a stretcher and kicker for $45 and used the pattern in the directions that Rusty sent. The hardest part was correctly assembling the stretcher: instructions were very basic and it took me a few attempts to get it right. After that, it was quick and easy.
None of the information I have seen mentioned stapling it down after hooking to the tack strips but I found that mine was when I took it up. I did not have that type staple so I substituted carpet tacks.
Old 05-02-2010, 05:43 PM   #5
Stretching carpet
Glad it worked out for you. Surprised it was srapled. It really shouldn't be.
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Stretching Carpet nitetrane98 Flooring 1 09-23-2007 06:06 PM
