Stranded Bamboo - Nail Or Glue - Underlayment Or Not - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2014, 09:51 AM   #1
Rewards Points: 18
Stranded bamboo - nail or glue - underlayment or not
Plan is to install 5/8 x 3 3/4 stranded bamboo in my (small) kitchen. Subfloor is plywood (house built in 1956). I have read a few warnings about using a nail gun on bamboo (splintering) so I was thinking of using glue instead. Also not sure if I need underlayment since there is a full (partially heated) basement below and moisture or noise is not really a factor.
Thanks in advance for any advice offered.
Al
iruser is offline   Reply With Quote
Old 03-19-2014, 12:54 PM   #2
Rewards Points: 13,694
Read the directions and or talk to the manufacture about this, there the one's going to be warrantying it.
Old 04-10-2014, 03:50 PM   #3
Rewards Points: 18
Thanks for the reply.
The manufacturer's warranty covers both nailing and glue. I am trying to decide which method I should use and what to do about underlayment. I am leaning toward using glue but I am not sure if the underlayment is okay to use with the glue.
Old 04-10-2014, 06:10 PM   #4
Rewards Points: 402
I have stranded bamboo and most places I talked to said it's too hard to nail into. The one place said they only recommend one particular brand of nailer and I believe they said staples, but I can't remember. Most places said to glue it down, or mine is actually floating with a foam underlayment and the seams are glued together. The manufacturer of my floor said it was ok to do it that way. All depends what your manufacturer says.
taylorjm is offline   Reply With Quote
Old 04-11-2014, 05:44 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It's almost impossible to staple. The staples just bend. You have to use cleats and yes they tend to cause it to splinter or split. We only sell locking floating strand now. Previously it was always best to glue the stuff. You shouldn't need any kind of underlayment when gluing.
Darkling Designs
poppameth is offline   Reply With Quote
Old 04-11-2014, 07:23 AM   #6
Rewards Points: 402
He's right, it was cleats they told me to nail it with, not staples. I would do the click lock stuff next time instead of the glue together if I was doing a floating floor again.
Old 04-15-2014, 05:51 AM   #7
Rewards Points: 18
Thanks much for the comments and advice. I will go with the glue.
I assume the underlayment isn't needed because the glue acts as seal and cushion to some degree. Any recommendation on the type of glue (or brand if that is allowed on here).
Thanks!
Old 04-19-2014, 01:58 AM   #8
Rewards Points: 744
Thanks!
Bostik urethane
http://www.bostik-us.com/markets/flooring/hardwood
Seattle2k is offline   Reply With Quote
Old 04-19-2014, 02:06 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
Hmmmmmmm
Guess I did it wrong.....I just put down 5/8" solid bamboo in our walk in closet. Nailed it.
No glue....nails only
Old 04-19-2014, 04:17 AM   #10
Rewards Points: 274
Basically it is always good to have a proper discussions with expert in this regard. so that to avoid the future loss.
alexjoe is offline   Reply With Quote
Old 04-19-2014, 08:23 AM   #11
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
That doesn't look like strand bamboo you put in the closet. Regular bamboo nails okay. Strand woven is a whole different monster. They tear the bamboo apart and weave it back together adding adhesives and resin before compressing and hardening it. It's twice as hard and normal bamboo, and twice an brittle when nailing.
Darkling Designs
The Following User Says Thank You to poppameth For This Useful Post:
taylorjm (04-19-2014)
Old 06-05-2014, 09:16 AM   #12
Rewards Points: 18
Hello again. After checking out all the options I decided to hand nail the bamboo. It will take time but it is a small enough project.
After getting started, I now have another question. When I removed the old tile flooring I found a black sticky coating covering the subfloor. The house was built in 1956. Does anyone know if it is ok to install (hand nail) the bamboo over top of this substance?
Thanks.
Old 06-05-2014, 02:36 PM   #13
Rewards Points: 430
Can't see why not. It is just tile mastic. Very hard to get off. Ron
ront02769 is offline   Reply With Quote
Roofing underlayment overlap jratlanta Roofing/Siding 6 02-28-2014 03:05 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
stranded Bamboo - on grade concrete Q's ametallo Flooring 2 03-09-2008 12:44 PM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 03:47 PM
Hardwood: Nail down and glue planks? digexpressions Flooring 3 11-30-2007 05:14 PM
