Stranded Bamboo - On Grade Concrete Q's - Flooring - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 09:03 PM   #1
stranded Bamboo - on grade concrete Q's
So here is the situation.
I like the stranded bamboo floors, but they can only be nailed or glued down. It is a fairly new material that is about 1/2" th thick and are not a typical engineered wood, but not really a hardwood either, so there is not much info about instalation. The other catch is, I think there is asbestos tile currently glued to the concrete. I only have an 1 1/2 between the concrete and the front door, so that is the most I can raise the floor.
Here is my plan - any warnings and advice would be very much appreciated.
I would like to
I will lay down 6 mil plastic then screw down half inch OSB to the concrete. Then I will glue down the floor.
I am a bit unsure about the lack of air flow under the floor. Also, what are some good floor leveling compounds?
ametallo is offline   Reply With Quote
Old 02-06-2008, 11:38 AM   #2
Floorwizard's Avatar
I am not a pro for this type of subfloor install but here is a couple q's.
How do you screw to concrete?
if you screw thru the poly, then how affected will that be on the water protection?
Floorwizard is offline   Reply With Quote
Old 03-09-2008, 12:44 PM   #3
Floating install for woven-strand bamboo
Check out Hilo bamboo (and a few others: google woven-strand flooring floating).
http://hilobamboo.com/wst_page2.html
kaloalex is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-19-2007 11:11 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 08:52 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
