Strand Bamboo On Existing Engineered On Slab? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 07:51 PM   #1
Strand Bamboo on existing Engineered on Slab?
we are getting ready to install new strand woven bamboo floors. we currently have 3/8" engineered floors glued to the slab. additionally, we are removing carpet from 2 rooms that meet with the current engineered flooring to install the bamboo. would it be possible to lay a 6 mil moisture barrier & 3/8" plywood in these two rooms to raise to level with the engineered-and then 15lb felt over everything and staple the new bamboo down?
i know the glue under the engineered acts as a moisture barrier, so just curious if we should rip all of it up, just to lay 6 mil and sub floor-or if we can lay on top?
jdavemb is offline   Reply With Quote
Tags
bamboo , engineered , install , subfloor
Room addition on existing cement slab and roof Cossack Building & Construction 6 06-20-2012 09:39 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 04:24 AM
Existing concrete slab has electrical and cat5 outlet. Would like smaller faceplates. noone Electrical 5 10-17-2011 02:29 PM
Building on existing concrete slab JimSpokane Building & Construction 2 07-22-2009 01:19 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
