Straight Ceramic Tile But Crooked Base Cabinet - Flooring - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 01:44 PM   #1
straight ceramic tile but crooked base cabinet
I ran into a situation where my ceramic tile is laid straigt on my subfloors but the base cabinet is crooked. So the tile that is going underneath the base cabinet will look crooked. The picture I attached explains better the situation. Is there a workaround for this situation?
Last edited by robismyname; 04-04-2011 at 01:50 PM. Reason: image was not attached due to size
robismyname is offline   Reply With Quote
Old 04-04-2011, 02:03 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
...well I think I would have run the first row of tile down the middle. Then the cuts to each side would have been bigger and an out of line cabinet might have been less noticable.
...or you can remove the screws in the cabinet and pull it straight.
12penny is offline   Reply With Quote
Old 04-05-2011, 10:57 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
What 12penny said. Either fix the cabinet or try different layouts until you find one that makes the situation less noticeable.
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 07:38 AM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
