Straight Answer On NON-poly Finished Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 01:48 PM   #1
Rewards Points: 540
Straight answer on NON-poly finished wood flooring
My floors are finished in both original and reclaimed wood flooring that does not appear to be poly-sealed; that is, if you run your finger on it, it leaves a smudge. You basically can't find anything in mainstream stores to maintain floors that aren't sealed with polyurethane. Meanwhile, I have scratches, water spots, dirt-- you name it. What am I supposed to use on this? There Johnson One-step, but it's wax and I'm told there are reasons wax is obsolete (soft, no help against heat) and I should use some sort of oil, like they use on bowling lanes. Suggestions?
operagost is offline   Reply With Quote
Old 04-29-2010, 09:14 AM   #2
The water spots would suggest to me that it's a wax finish. Bruce had a product called Light & Bright and Dark & Rich which was a paste wax that worked well on these types of floors (if you can find out for sure that it is a wax finish.) You may need to start with the stripper first if you've got significant marking and water spots.
I did a quick google search and it looks like it's still available too. These paste waxes are a little different in that they contain a cleaner too.
Hope that helps!
rcuerrier is offline   Reply With Quote
The Following User Says Thank You to rcuerrier For This Useful Post:
operagost (04-29-2010)
Old 04-29-2010, 10:13 AM   #3
Rewards Points: 540
Thanks! I'm thinking that long-term, I'll want to switch to tung oil or add poly, but for now I'd like to keep using whatever the previous owner probably used (unfortunately, I never thought to ask) so that's very helpful to know.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Self levelling compund for wood flooring Mackenziewood Flooring 3 04-22-2010 05:22 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 03:20 PM
