Old 09-26-2014, 03:57 PM   #1
Rewards Points: 2
storage of reclaimed maple hardwood - freezing ok?
Hi there, I recently purchased 1200 sq ft of 3/4" reclaimed maple hardwood. It was originally installed as a gymnasium floor, and was pulled up, plank by plank. I'll be installing it in my house (new construction), but won't be ready for it until December or later. It's currently in an un-insulated shipping container on site. Is it ok to freeze as long as I acclimate it prior to installation?
Thanks!
Silverthorn is offline   Reply With Quote
Old 09-26-2014, 11:09 PM   #2
Rewards Points: 3,150
Moisture and not sticking it is far more important then temperature.
Sticking is nothing more then wooden slats so there's air flow all around the pieces.
Moisture is going to cause cupping, curls and twist.
Hope this works out for you trying to recycle.
Could have installed prefinished floor and walked on it the same day and had about 7 layers of finish already on it. And there would be no missing tongues and groves from where the nails ripped out, bottoms would be flat with no flaws to deal with, no sanding dust, no having to wait for anything to dry.
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 05:50 PM
attic storage storageseeker Building & Construction 2 01-29-2009 08:02 AM
reclaimed maple hardwood cbeingessner Flooring 1 06-16-2008 08:08 AM
OLD Hardwood ( maple ) on a concrete slab MrLinux Flooring 1 01-31-2008 09:47 PM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
