Stiffest Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2008, 01:03 PM   #1
stiffest underlayment?
Sorry if this is a repeat, I am new here and didn't find an answer to my specific question. Here is my situation - built 1947, joist and subfloor in good shape. Subfloor is diagonal 3/4 boards nailed to 2 x 10 joists with about 1/4 in. gap between the boards. I would like to use the THINNEST stiffest backer for real slate tiles (ashlar pattern, 12 in and smaller), and I thought maybe if I buy thin (1/4 or 3/16) and double it, screwing, overlapping the seams. everything I read says 1/2 inch, but this seems like overkill if using concrete board. Wouldn't this be stiffer than using 1/2 inch? . Help?
Althumbs is offline   Reply With Quote
Old 04-24-2008, 01:30 PM   #2
RippySkippy's Avatar
Since you don't mention the length of the joist, it's almost impossible to determine the floors ability to handle the load. Head on over to the John Bridge forum and use his Deflecto meter, and that'll give you an idea of what will and will not work.
I'm sure a pro will chime in...but the backer board or underlayment is NOT typically considered to improve the structural integrity of the sub-floor. Using two sheets of 1/4 is nothing but more work than using a single 1/2". What ever you end up using...make sure to use thin-set between the backer and subfloor.
RippySkippy is offline   Reply With Quote
Old 04-24-2008, 05:49 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Althumbs,
You are using the wrong approach. Plywood is stiffer than cement board.
Not only that....a stone floor requires double the rigidity of that required for ceramic tile.
The 3/4" boards are also a problem for you and they should have plywood over them before any cement board can be used.
If you think the use of 1/2" cement board is overkill then you need a better understanding of what it takes to do a job like you want to do if you want it to last.
What is the unsupported span of the floor joists and how big is the area you want to tile?
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
Underlayment dhar2112 Flooring 3 04-15-2008 12:38 AM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 03:17 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 05:54 PM
