Stiffening Up My Floating Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 09:31 AM   #1
stiffening up my floating floor
Over the weekend, I installed approximately 700 ft² of US Floors strand woven floating bamboo floor. (EXCELLENT product, by the way. ZERO waste to speak of, other than my errors). However, under a large doorway between kitchen and living room, there is an area that feels "spongy". It's obviously due to me not getting my subfloor level in that spot. (IDIOT!) It's maybe 2 feet wide, and runs perpindicular to the boards about 6 feet.
It's a "drop n lock" install, not T&G.
To tighten it up, I plan on cutting and removing one board (hopefully not more) and sliding maybe real thin plywood under the 3 in 1 underlayment in this area, with hopes that it will take the flex out of the bamboo, then reinstalling and gluing the bamboo board back.
Does this seem like a viable option from here? Obviously, there are a lot of "should haves" but it's too late to tear up the floor and start again.
Thanks for any and all advice.
Mr. Michael is offline   Reply With Quote
Old 10-23-2012, 11:55 AM   #2
Rewards Points: 150
Stuff happens. You might consider using a door skin for a shim material, given the dimensions of your low spot.
zakany is offline   Reply With Quote
Musty smelling basement with a floating floor TSullivan Building & Construction 12 10-08-2012 02:38 PM
Pergo floating floor on existing hardwood ? ants1929 Flooring 4 02-01-2011 02:54 PM
Ideas for hiding gaps between floating floor and wall/trim AnthraciteDude Flooring 2 01-29-2011 05:07 PM
Vapor barrier between leveled subfloor and floating floor sjkm Flooring 2 06-13-2009 11:17 AM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 02:10 PM
