Stiff Enough For Ceramic Tile ? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 08:51 PM   #1
Rewards Points: 201
Stiff enough for ceramic tile ?
My subfloor is 3/4" Avantech T&G, screwed and glued, on 2x8 joists on 19.2 centers spanning 7.5'.
Is this stiff enough for ceramic tiles, and if so what is the name of the 'backer board' that needs to go over the subfloor before laying the tiles ?
And does it (backer board) come in different thicknesses; if so, what thickness should I use, and what is the best way to attach it to the subfloor ?
And should I limit the size of the tiles to 12" square, rather than the larger tiles to lessen the chance of cracking ?
Also, if tiles are ok, are ceramic tiles ever used in living rooms or bedrooms, or would that be kind of weird ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 03-07-2012, 09:05 PM   #2
DIY staff
Rewards Points: 7,174
You are solid as a rock--918---360 is minimum for tile--720 minimum for natural stone--
Backer for floors is 1/4"--also available in 1/2" if you need to add height--
Set backer into a bed of fresh thinset--1/4 x1/4 trowel--roofing nails or rock screws see the manufactures instructions for nailing pattern--
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
