-   -   sticky tiles over linoleum? (http://www.diychatroom.com/f5/sticky-tiles-over-linoleum-70166/)
Bushman 04-29-2010 03:15 PM
Hi all,
Can I install self stick tiles over linoleum?
I live in a rental and the landlord won't replace the worn out and stained white linoleum in the kitchen. I have looked at stick tiles and they are "affordable" for a rental. What would be the correct process?
Thanks,
rusty baker 04-29-2010 06:19 PM
Is the old vinyl stuck down everywhere? How deeply embossed is the old vinyl?
Russman 04-29-2010 06:28 PM
stick tile
I have done it before. Like the response below, you have to make sure the vinyl is smooth and flat with no ends curling etc. Stick the first row down and see how well it sticks. Usually if there is no problem, you should be ok for the rest of it. Make sure you run the arrows on the back of tiles the same direction as well.
Good luck
Russ
Bushman 04-29-2010 06:52 PM
It is stuck down pretty good and not deeply embossed. Although I could see problems if a joint landed on a embossed seam. Thanks for the input.
rcuerrier 04-30-2010 08:07 AM
The easiest and best way to ensure you don't have any telegraphing or problems having to do with the embossing of the existing vinyl floor is to skim it first using an embossing leveller.
The embossing leveller serves two purposes. The first, evident by its name, is to fill any embossing existing in the existing floor thus creating a smooth surface. The second is to ensure a surface to which your tile will bond properly. Over the years the existing floor has been cleaned a variety of ways with cleaners that may or may not have been appropriate and have likely left a buildup of residue behind. If you use an embossing leveller you are able to significantly reduce the potential failure rate of peel and stick tile.
Hope that helps!
PS, Here's a helpful document from Armstrong pertaining to the preparation of your existing floor prior to installation. http://www.armstrong.com/content2/resam/files/44963.pdf
:thumbsup:
rusty baker 04-30-2010 08:35 AM
Make sure you have your landlord's permission. Even fixing things can violate your lease.
