Sticky Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 10:44 AM   #1
Gymschu's Avatar
Rewards Points: 506
Sticky subfloor
After removing some 2 x 2 self stick tiles in a kitchen, the subfloor is coated in adhesive that is extremely sticky, to the point that if you stand on it you get stuck like a fly to flypaper. Is there anything that can be put on the subfloor to make it less sticky or am I destined to lay a new subfloor?
Old 07-10-2011, 12:18 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
what do you plan on putting down now? baby powder will make the floor less sticky
mustangmike3789 is offline   Reply With Quote
Old 07-10-2011, 02:12 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What are your plans Gymschu what are your plans?
XXX
Old 07-10-2011, 04:21 PM   #4
Gymschu's Avatar
Rewards Points: 506
Gonna be laying down sheet vinyl to replace the individual square tiles.................never thought about baby powder..........it's just a pain to work around this sloppy, sticky mess.
Old 07-10-2011, 04:52 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
Will you be gluing or loose laying the vinyl?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 07-10-2011, 04:55 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well that's going to be a mess and make the sheet vinyl installation difficult at best.
There are products available commercially that can be used to remove the old adhesive but it's a lot of work and a mess to deal with.
We have used a reducer product called "Detach", there are others. Once the reducer is down and working you must scrape up the mess, and it turns into a sticky snot-like material. We have also used "Oil-Sorb" or "cat litter" to bulk-up the snot and help dry it to make it more manageable.
XXX
Old 07-10-2011, 05:37 PM   #7
m1951mm's Avatar
Here is a question for you Pros??? Would it be better to leave the old flooring in tack and going forward from there. I think I know, if tile is going down the problem can be eliminated with backer board or durarock. Please let me know if I am out of the ballpark. If laminate is going in, a new sheet of 1/4 luane (sp??) would take care of the issue. I would love to learn more.
m1951mm is offline   Reply With Quote
Old 07-10-2011, 06:43 PM   #8
Gymschu's Avatar
Rewards Points: 506
Thanks all for the suggestions. I'm thinking the least messy and probably best solution IS to lay down some luan..........
Would you replace this subfloor? winterminute Flooring 2 11-30-2010 11:48 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
