Sticky Hardwood Floor Stain After 5 Days - Flooring - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 02:15 PM   #1
Unhappy
Sticky Hardwood Floor Stain after 5 days
I put stain on my hardwood floors, but did not wipe them off as instructed because I liked the color. It's 5 days later and the floors are still sticky. Any suggestions on how to get them dry so I can start applying the polyurethane? Also, the bottle of poly states to apply 2-3 coats and once the final coat is on, not to put anything heavy on the floors for 14-21 days. Is this true? I was hoping to move in a week after the poly coats were applied.
new owner 730 is offline   Reply With Quote
Old 05-21-2009, 02:28 PM   #2
Rewards Points: 150
As you have already found out, not following instructions and guidelines leads to an unsatisfactory result.
That stuff is on the can for a reason
try putting a fan on your stain but im thinking it needs a good wiping
mike costello is offline   Reply With Quote
Old 05-21-2009, 05:32 PM   #3
You shouldn't need to wipe stain off. But that ofcourse depends on the process/prepping you did when you applied it. Stain should never take that long to dry.
TheFloorGuy is offline   Reply With Quote
Old 05-24-2009, 07:14 AM   #4
Rewards Points: 266
stain was pobably to thickly put on. run some fans and dehumidifier. Your prolly gonna have to buff off what hasnt already dried. use an oil based poly to seal everything. Waterbased poly will cause problems with this stain.
you can move tables/chairs in after 5 days. DO NOT put any rugs or anything that prevents air circuting over the floors for 3-4 weeks. The poly needs time to cure.
If say a rug is put down withing 1 week. If you take that rug up in 3 months there is gonna a noticable dark area showing where the rug was. The rest of the floor will be lighter due to curing and UV lights
good luck
What have I done is offline   Reply With Quote
Old 05-25-2009, 06:27 PM   #5
I ALWAYS wipe my stain off. Otherwise there is potential for bonding issues.
floortrends is offline   Reply With Quote
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
