-   -   Sticky Hardwood Floor Stain after 5 days (http://www.diychatroom.com/f5/sticky-hardwood-floor-stain-after-5-days-44955/)
new owner 730 05-21-2009 02:15 PM
I put stain on my hardwood floors, but did not wipe them off as instructed because I liked the color. It's 5 days later and the floors are still sticky. Any suggestions on how to get them dry so I can start applying the polyurethane? Also, the bottle of poly states to apply 2-3 coats and once the final coat is on, not to put anything heavy on the floors for 14-21 days. Is this true? I was hoping to move in a week after the poly coats were applied.
mike costello 05-21-2009 02:28 PM
As you have already found out, not following instructions and guidelines leads to an unsatisfactory result.
That stuff is on the can for a reason
try putting a fan on your stain but im thinking it needs a good wiping
TheFloorGuy 05-21-2009 05:32 PM
You shouldn't need to wipe stain off. But that ofcourse depends on the process/prepping you did when you applied it. Stain should never take that long to dry.
What have I done 05-24-2009 07:14 AM
stain was pobably to thickly put on. run some fans and dehumidifier. Your prolly gonna have to buff off what hasnt already dried. use an oil based poly to seal everything. Waterbased poly will cause problems with this stain.
you can move tables/chairs in after 5 days. DO NOT put any rugs or anything that prevents air circuting over the floors for 3-4 weeks. The poly needs time to cure.
If say a rug is put down withing 1 week. If you take that rug up in 3 months there is gonna a noticable dark area showing where the rug was. The rest of the floor will be lighter due to curing and UV lights
good luck
floortrends 05-25-2009 06:27 PM
I ALWAYS wipe my stain off. Otherwise there is potential for bonding issues.
