Sticky Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 11:09 AM   #1
Sticky Floor
Pulled up a carpeted area to go back to the old hardwood floors. Found where the previous owner put down sticky back tiles. Needless to say the sticky is still on the nice hardwood floor. Does anyone have any ideas what to reduce the stickiness prior to sanding?
CarolinaHawk is offline   Reply With Quote
Old 05-15-2011, 12:04 PM   #2
woodman58's Avatar
The glue will have to be removed before sanding. If not it will gum the sandpaper up. I don't know of a chemical that will remove the glue without getting the floor too wet. Hopefully someone else will. Otherwise you will probably have to cover the floors or replace them.
woodman58 is offline   Reply With Quote
Old 05-15-2011, 01:38 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You could try some adhesive remover and a scrubbee but don't flood the floor with the juice. Paint it on with a brush then scrub it with the scrubbee then wipe it with a cloth with juice in it. Gonna take some time. May also get into and lift any prior finish that was applied earlier.
XXX
Old 05-15-2011, 09:59 PM   #4
i would try denatured alcohol or mineral spirits with plenty of ventilation. they will not hurt the floor. when putting poly down they recommend wiping the floors down with mineral spirits before the first coat .
Old 05-16-2011, 06:19 PM   #5
Rewards Points: 1,578
"when putting poly down they recommend wiping the floors down with mineral spirits before the first coat ."
I assume only for oil-based polys?
bob22 is offline   Reply With Quote
Old 05-16-2011, 07:51 PM   #6
We decided to put down a floating floor to save my back/sanity lol.
Thanks for the feedback
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
