Old 05-09-2006, 04:18 PM   #1
Question Step by step
No pun intended, but I'm looking for a step by step description of how to install laminate on stairs. I've heard the pros & the cons of it and and now I'd just like to understand it, please.
I know there are boards & nose pieces, but I'm not entirely sure how they are all to be secured. Glue perhaps?
The stairs concerned do have an overhang of approximately 3/4", and so I imagine we'd build up the riser, rather than cut it off to be flush, if that makes sense.
Looking forward to understanding the nuts and bolts of it. Thank you!
Trishl is offline   Reply With Quote
Old 05-10-2006, 08:27 PM   #2
Super Moderator
Floorwizard's Avatar
yes, glue it with liquid nails if you want.
building up or cutting off either way will work. Just understand that you will have a smaller step with a more slippery surface.
don't get hurt now
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 05-13-2006, 12:03 AM   #3
florcraft is right - although he didnt really say it, it would make it more dangerous ascending and descending. Or you could have a big mattress at the bottom so you bounce and not break anything.:D
lxdollarsxl is offline   Reply With Quote
More On This Topic
3/4 Size Guitar Tips
3/4 Size Guitar Tips by Expert Village
Let's take a look at a three-quarter scale guitar, again, suitable for young people or somebody needing a much smaller sized instrument. These are entry-level instruments, but much higher quality ones can be gotten. For most people, and youth that are... Read More »
Hi! My name is Evan Blankenship with expertvillage.com, and I'm going to be teaching you how to backside 180. Alright, so now that you can back 180 down a curb, you want to take it to something a little bit bigger. Find a nice stair set, 2 stair, 3 stair... Read More »
Hi, my name is Evan Blankenship with Expert Village. I'm going to be teaching you how to pop shuvit. Now that you got your pop shuvit good you can pop shuvit a gap and down a curb, you can do it on a step. A good size stairs set to start out with is a 3... Read More »
Hi, I'm Steve Chubin at Steve's Sewing and Vacuum Center at King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. On accessory vacuums, what you have here is a hand vac. These vacuums are very convenient to use for cleaning... Read More »
Hi, I'm Rachel for Expert Village. Now I'm going to take the pictures, all of them actually and then I'm going to do lamination. If you don't want to use the whole lamination paper you can just see how much space you'll need for all your pictures. And... Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Do architectural shingles really work with step flashing? Malcolm Roofing 7 05-03-2008 12:31 AM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 01:34 PM
Ceramic tile on a little step... kbens74 Flooring 8 01-04-2007 12:45 PM
tile step into whirlpool ekaplan1020 Remodeling 1 04-09-2006 12:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
