#1 |
Steam shower tile
I am putting in a steam shower and have done all the prep excpt the tile.
I have lined the framed walls with 6 mil plastict instaled cemet wallboard a, sealed the cracks and applyed 2 coats of Mer-Krete Hydro-Guard SP-1 and use the fabric on all corners. Now before i tile on top of this, my question is, is the tile mortor going to stick to this rubber membraine. If so what is the best thin set to use and the best grout to use in a steam shower. Thank you for your help. |
#2 |
Tileguy
Steam shower tile
You should contact Mercrete to see if that product is suitable for a steam shower application. My information is that all of the liquid applied waterproofing membranes are not suitable for steam room applications because they will transmit water vapor. They are not a shield against water vapor. Water droplets yes, water vapor no. There is a difference.
![]() Get your final word from the waterproofing manufacturer on this subject.
#3 |
Steam shower tile
This is my steam shower. I did everything you did except I just used the membrane on the seams. I wasn't sure if you were saying you coated the whole thing. We use it every day and have never had any problems at all. In fact, the other week I had to cut out a piece of drywall on the other side of the shower and it was bone dry. As far as the mortar adhering to the membrane, again, not sure if you coated the entire thing. If so, I would definitely talk to the manufacturer. If you just did the seams, you should have no problem.
#4 |
Tileguy
Steam shower tile
Don't sound so confident my friends. There are many problems with steam showers on a regular basis. You should do more research before you follow the advice of someone here that also doesn't know the recommendations.
What is being and has been done in these two referenced showers IS NOT in the industry recommendations from any source.
#5 | |
Steam shower tileQuote:
#6 |
Tileguy
Steam shower tile
Just sayin'......
![]() Shootin' from the hip isn't the way to approach it.
#7 | |
#8 | |
Tileguy
#9 | |
www.No-Curb.com
Both Custom Building Products and Laticrete have steam shower installation details. What Bud mentions is correct but the liquid membrane approach includes the use of 6 mil poly. Laticrete's installation guide on steam showers is outstanding. Here in vancouver we build our steam showers with sheet membranes and use Noble Seal TS for it's low low perm rating of 0.05 JW
" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - John Whipple Contact Info: Email
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Phone: 604 506 6792 Alternate Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Tags |
best grout, best thinset, steam shower ![]() |
| Display Modes | |
| Crack in old shower tile | Jeff DIY | Flooring | 21 | 01-15-2012 03:11 PM |
| Honey, I'm going to re-caulk the shower... | homebound | Remodeling | 1 | 02-10-2009 10:11 AM |
| Another newbie building a tile shower | ChadC | Building & Construction | 7 | 08-25-2008 03:58 PM |
| Plastic shower surround on top of tile ok? | 1973vw | Remodeling | 4 | 04-09-2008 01:22 AM |
| Building a tile shower | ghostrider20 | General Discussion | 2 | 03-01-2007 09:54 PM |
