Starting My Flooring Project... - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 07:30 PM   #1
Starting my flooring project...
First post here!
I just pulled up the carpet in a room in our house, and I'm planning to put in a hardwood floors in part of the house, and tile in the other part.
The room is 33' long, and 9'8" wide.
The front 1/3 of the room is concrete, and the back 2/3 is some type of plywood (large sheets).
In a couple of places, the plywood sinks down a bit (there is some give in the floor), but we jumped up & down on it today, and overall it seems solid.
Questions:
1) Do I need to strengthen the plywood in order to lay hardwood floors on it?
2) What underlayment do I need for hardwood floors (on top of the plywood)?
3) What underlayment do I need for tile (on top of the concrete)?
Thanks!
~ Charles
cbb7855 is offline   Reply With Quote
Old 01-13-2008, 08:40 PM   #2
Rewards Points: 150
sounds like you need a sub floor down before the wood
comp is offline   Reply With Quote
Old 01-13-2008, 08:42 PM   #3
Rewards Points: 266
if your using 3/4" flooring you should be ok. Run the flooring in the opposite diection of your floor joists.
What have I done is offline   Reply With Quote
Old 01-13-2008, 08:54 PM   #4
What is a sub-floor? Is this the same thing as hardiboard?
~ Charles
Old 01-13-2008, 08:55 PM   #5
How do I know which direction my floor joists are running?
Also -- a floor joist is the thing holding the layer of plywood up, right?
~ Charles
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 01:47 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
