-   -   Starting my flooring project... (http://www.diychatroom.com/f5/starting-my-flooring-project-15566/)
cbb7855 01-13-2008 07:30 PM
First post here!
I just pulled up the carpet in a room in our house, and I'm planning to put in a hardwood floors in part of the house, and tile in the other part.
The room is 33' long, and 9'8" wide.
The front 1/3 of the room is concrete, and the back 2/3 is some type of plywood (large sheets).
In a couple of places, the plywood sinks down a bit (there is some give in the floor), but we jumped up & down on it today, and overall it seems solid.
Questions:
1) Do I need to strengthen the plywood in order to lay hardwood floors on it?
2) What underlayment do I need for hardwood floors (on top of the plywood)?
3) What underlayment do I need for tile (on top of the concrete)?
Thanks!
~ Charles
comp 01-13-2008 08:40 PM
sounds like you need a sub floor down before the wood
What have I done 01-13-2008 08:42 PM
if your using 3/4" flooring you should be ok. Run the flooring in the opposite diection of your floor joists.
cbb7855 01-13-2008 08:54 PM
What is a sub-floor? Is this the same thing as hardiboard?
~ Charles
cbb7855 01-13-2008 08:55 PM
How do I know which direction my floor joists are running?
Also -- a floor joist is the thing holding the layer of plywood up, right?
~ Charles
