Staples Vs Nails - Flooring - DIY Chatroom Home Improvement Forum
Old 04-26-2007, 09:02 AM   #1
staples vs nails
I believe we are going to install solid 3/4" solid white oak flooring. Probably 3.25" width or larger, don't know yet. I was in a small contractor supplier type store the other day that specializes in selling mostly pneumatic nail & staple guns. I had read a few blogs that staples were superior to nails in holding strength. However, the guy informed me that in his experience, nails are a better choice for solid 3/4" flooring and staples are a better choice if your permanetely securing engineered flooring. Any consensus or disagreements from users/readers? I have 3/4" plywood subfloor on 16" O.C. 2X10 joists.
shotdown is offline   Reply With Quote
Old 04-26-2007, 09:33 AM   #2
Master Craftsman
Big Dave's Avatar
I've got one of each and prefer the stapler over the cleat nailer. One difference is I install mostly pine which is a soft wood which allows the nails to pull through too easily.
I've installed prefinished hardwood oak with the stapler with no ill effects.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 04-26-2007, 10:46 AM   #3
Rewards Points: 1,088
Based on my experience, the staples hold a bit better.
handy man88 is offline   Reply With Quote
Old 04-26-2007, 05:55 PM   #4
Home Improvement Guy
ron schenker's Avatar
I've installed hardwood with both and they both are good. I've ripped out hardwood with both and had a much tougher time with the staples. Oh, and use 2" length with either one.
ron schenker is offline   Reply With Quote
Siding Nails Clutchcargo Carpentry 20 06-16-2007 04:33 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
