Staples or screws on plywood subfloor? And other questions....
We just ripped out our ceramic floor and cement board down to 3/4 tongue an dgroove wood plank. There was shrinkage of this board and not totally firm as lots of springyness. Right now we are putting on 5/8 smooth plywood with the intention of putting cheap vinyl on for a short while and then a glue down cork floor. I have several questions...
1. What size nails, staples, or screws? We put in some screws in the plywood and it was hard to get then a little countersunk. They were either too high or were being countersunk too low. Some of the heads were popping off. We were using 1 5/8 construction screws which i thought was too long and i thought 1 1/4 was too short. I called 2 stores in town and they don't carry 1 1/2 inch screws. Frankly, i was worried that the 1 5/8 might hit my plumbing in the basement. There is A LOT of plumbing in my basement. There has got to be an easier way.
2. What do you use to fill dents and where the plywood meets?
3. How close do you butt the plywood? My local menards said to put them tight together. Though i have heard other advise.
4. Is the plywood sufficient for glue down cork? Or do i need to put a luan down later?
Thanks for all the advise.
Reason: Add info
