Staple Nubs In Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 11:12 AM   #1
Rewards Points: 4,796
Staple nubs in hardwood floor
Removing the carpet in a house and refinishing the hardwood floors underneath. The pad was stapled down with many staples. When pulling them out, most came but some broke off, leaving sharp little nubs sticking up a 32nd of an inch or so. I'm not worried about how this will look because they're basically invisible, but I'm worried about sanding over them. Standard belt sander starting around 60 grit or so - will the nubs be sanded down, or will they shred the sandpaper? If so, suggestions for removing? Pulling out with pliers is not an option since there's not enough to grip. Grinding down with a 4" diamond wheel is an option, but that sounds tedious and prone to gouging the wood if not really careful.
jeffnc is offline   Reply With Quote
Old 03-06-2012, 12:26 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Use a pair of nippers or side cutters to pull them.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-06-2012, 05:19 PM   #3
They're not long enough for that, or the ones that barely are won't grab - the tip just mushes or breaks off. I'm talking about the staples that won't come out. Even if they're flush with the surface, the sander will sand down into the tips of them as it grinds into the wood.
Old 03-06-2012, 06:17 PM   #4
Experienced
Jackofall1's Avatar
How about knocking in or over, that way when you sand they won't have that sharp point to catch the paper.
Mark
Old 03-06-2012, 06:33 PM   #5
Learning Things Every Day
Jay 78's Avatar
A hammer and a punch, or break out your Dremel. The former is the better idea, IMO.
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-06-2012, 06:45 PM   #6
Knock in like with some sort of nailset? Is there something you can think of that would work without creating a hole?
What did you have in mind by "knocking over" - that might work - what, with an old chisel or something?
Old 03-06-2012, 06:57 PM   #7
Jay 78's Avatar
Under Construction
Old 03-06-2012, 07:03 PM   #8
Yes I know what a nailset is I was talking to JackOfAll. The Dremel idea might work though, I might give that a try.
Old 03-06-2012, 08:40 PM   #9
Experienced
Jackofall1's Avatar
Just knock them flat, the sander will finish them, you will be taking off at least 1/32" of material, the staple tops will be long gone.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
oh'mike (03-08-2012)
Old 03-08-2012, 01:08 AM   #10
They will be hard on the sandpaper. Have you tried using a wire cutter? not to cut the staple but to grab it closer to the wood and pull it out.
jastin123 is offline   Reply With Quote
Old 03-08-2012, 06:29 AM   #11
DIY staff
Rewards Points: 7,174
Just do what Jackofall suggested---the sand paper can handle those staples---
Old 03-08-2012, 07:04 AM   #12
the Musigician
DangerMouse's Avatar
I had this problem once, I used needle-nosed pliers that I had touched the tip to a grinder to shape them properly and it worked very well.
DM
Old 03-08-2012, 07:15 AM   #13
Rewards Points: 82
Never had staples that I couldn't pull with side cutters.
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Carpet on hardwood floor, threshold hoozgrunt Flooring 1 07-15-2009 09:53 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
