-   -   Staple nubs in hardwood floor (http://www.diychatroom.com/f5/staple-nubs-hardwood-floor-136173/)
jeffnc 03-06-2012 11:12 AM
Removing the carpet in a house and refinishing the hardwood floors underneath. The pad was stapled down with many staples. When pulling them out, most came but some broke off, leaving sharp little nubs sticking up a 32nd of an inch or so. I'm not worried about how this will look because they're basically invisible, but I'm worried about sanding over them. Standard belt sander starting around 60 grit or so - will the nubs be sanded down, or will they shred the sandpaper? If so, suggestions for removing? Pulling out with pliers is not an option since there's not enough to grip. Grinding down with a 4" diamond wheel is an option, but that sounds tedious and prone to gouging the wood if not really careful.
rusty baker 03-06-2012 12:26 PM
Use a pair of nippers or side cutters to pull them.
jeffnc 03-06-2012 05:19 PM
They're not long enough for that, or the ones that barely are won't grab - the tip just mushes or breaks off. I'm talking about the staples that won't come out. Even if they're flush with the surface, the sander will sand down into the tips of them as it grinds into the wood.
Jackofall1 03-06-2012 06:17 PM
How about knocking in or over, that way when you sand they won't have that sharp point to catch the paper.
Mark
Jay 78 03-06-2012 06:33 PM
A hammer and a punch, or break out your Dremel. The former is the better idea, IMO.
jeffnc 03-06-2012 06:45 PM
Knock in like with some sort of nailset? Is there something you can think of that would work without creating a hole?
What did you have in mind by "knocking over" - that might work - what, with an old chisel or something?
Jay 78 03-06-2012 06:57 PM
http://www.hardwarestore.com/media/p...2_front200.jpg
jeffnc 03-06-2012 07:03 PM
Yes I know what a nailset is :) I was talking to JackOfAll. The Dremel idea might work though, I might give that a try.
Jackofall1 03-06-2012 08:40 PM
Just knock them flat, the sander will finish them, you will be taking off at least 1/32" of material, the staple tops will be long gone.
Mark
jastin123 03-08-2012 01:08 AM
They will be hard on the sandpaper. Have you tried using a wire cutter? not to cut the staple but to grab it closer to the wood and pull it out.
oh'mike 03-08-2012 06:29 AM
Just do what Jackofall suggested---the sand paper can handle those staples---
DangerMouse 03-08-2012 07:04 AM
I had this problem once, I used needle-nosed pliers that I had touched the tip to a grinder to shape them properly and it worked very well.
DM
rusty baker 03-08-2012 07:15 AM
Never had staples that I couldn't pull with side cutters.
