Old 07-14-2012, 01:57 PM   #1
Stairway tread
What type of wood should I use for indoor stairs.
g_newport is offline   Reply With Quote
Old 07-14-2012, 02:09 PM   #2
Stairway tread
exposed or carpeted or painted?
Old 07-14-2012, 02:25 PM   #3
Stairway tread
It's got carpet on it
Old 07-14-2012, 02:26 PM   #4
Stairway tread
I'm wanting to take the carpet up
Old 07-14-2012, 05:23 PM   #5
Stairway tread
That's up to and how you want it to look and how much money you want to spend.
Most common are pine and red oak but there's dozens of other wood they can come in.
Just Google "stair treads" to see some ideas.
Old 07-15-2012, 07:31 PM   #6
Stairway tread
You may have wood under the carpet. It does not hurt to check. Then you could save a lot by just refinishing these. If you don't the most common woods on stairs would be oak or maple.
Awoodfloorguy is offline   Reply With Quote
Old 07-15-2012, 09:25 PM   #7
Stairguy
Stairway tread
Whatever your floors are or are going to be
Millertyme is offline   Reply With Quote
Exterior stair landing tread size min/max? jackwashere Building & Construction 17 01-06-2012 03:15 PM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
Stairway tread options bfraer4070 Flooring 0 02-22-2010 12:28 PM
R311.5.2 HEADROOM stairway code in Michigan question DoobieG Building & Construction 13 01-29-2010 06:55 PM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
