Stairway Transformation - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 03:34 PM   #1
Hello All,
I'm looking at tearing the carpet off my split level stairs and installing stair treads, which I will stain and finish myself. I'm also looking at staining the newel posts and handrails the same color as the stair treads, but leaving the balusters white. My questions are:
1) How can I remove the balusters without damaging them?
The ones on the stairs are not a problem as they will have to be shortened just a bit to make room for the treads; I can cut them out. I would like to remove the ones on the main level to make the sanding, staining, and finishing of the handrail easier, however I would like to be able to use the old balusters; therefore no cutting them out. Is this possible? Or will I have to simply buy new balusters?
2) How do I make the transition from wood stairs leading up to a carpeted floor?
3) Is it possible to make my own treads?
I have decent experience with wood work and I have access to all the tools I would ever need.
Thanks for the input guys and gals.
Blake
brdehaan is offline   Reply With Quote
Old 09-22-2011, 04:34 PM   #2
Framing Contractor
Rewards Points: 100
1) We would need a pic to see what kind of ballusters you have. Some come off easier than others.
2) This can be done using a hardwood nosing at the carpet edge.
3) It is possible to make treads, although I don't see the point. They are readily available and affordable.
Changing out the treads and risers is probably gonna be harder than you think. You can't just slap new treads on top of old, as this will change the rise of the top and bottom steps.
sixeightten is offline   Reply With Quote
Need assistance installing brazilian cherry stairway BobS0327 Carpentry 8 09-07-2010 11:30 AM
Stairway skirtboard YEVRAH Carpentry 5 07-20-2010 10:24 AM
R311.5.2 HEADROOM stairway code in Michigan question DoobieG Building & Construction 13 01-29-2010 06:55 PM
Finishing basement stairway Richo Carpentry 26 03-09-2009 05:28 PM
Stairway loose asegal General DIY Discussions 4 12-02-2006 05:00 PM
