Stairway Stringer? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 11:58 AM   #1
Stairway stringer?
I am installing hardwood floor in my family room, there are three steps from the kitchen down into this room. What I would like to know is where these stringers sit on the subfloor shoud I floor around them or cut them off the 3/4" and go under them?
Thanks in advance!
roar24 is offline   Reply With Quote
Old 12-13-2009, 12:12 PM   #2
Go around them, stringers are supporting the stairs
You don't cut them
Old 12-13-2009, 05:19 PM   #3
Remodeling Contractor
Cut around them. But.... this means you are adding 1 1/4" to the floor. Now the bottom step is that much less than all the others. This is very unsafe and against codes. If you are installing laminate flooring you might get away with it. But then you need to cut around anyway since these are floating floors and you need a clear gap at all edges so the floor does not buckle.
Old 12-13-2009, 05:22 PM   #4
Chicago, IL
Michael Thomas's Avatar
To be exact about Bob's point: if you floor around the stringers will the stairs comply with IRC R311.5.3.1?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Stairway skirt board template - easy Richo Carpentry 14 08-26-2011 04:03 PM
Plywood Stair Stringer ralphfravel Carpentry 4 11-01-2009 09:39 PM
Screwed up stair stringer (picture in thread) iMisspell Building & Construction 9 11-13-2008 10:49 AM
Stairway loose asegal General DIY Discussions 4 12-02-2006 04:00 PM
