Stairs In Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 08:22 AM   #1
Rewards Points: 1,050
Stairs in laminate
Hello
I was looking at that tutorial to put laminate on my stairs:
http://www.laminate-flooring-install...on-stairs.html
It is really really great, and very well explained....
I just have 1 question though: what type of wood should be used for the riser?
I was think at some MDF maybe....?
french_guy is offline   Reply With Quote
Old 01-20-2013, 09:58 AM   #2
Rewards Points: 13,766
I'd never suggest anyone use laminite on stairs, far better look, and easyer to use real wood treads.
Lots or reasons not to do it.
Laminite has to have room to expand and contract.
Slippery
Not wide enough to be used for a full tread so you end up with a narrow strip that can open up.
No good way to trim it out without a bunch of trip hazzards
The stair nosing I've seen used is noting more then compressed paper with a vinyl foil that looks like shelving paper over it. So it wears through.
It also has a 90 deg dato on the back side creating a weak spot where it can crack.
MDF for the risers can be used but real wood holds up better to abuse.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
BigJim (04-02-2013), Dave Sal (04-01-2013), rossfingal (04-02-2013)
Old 01-20-2013, 11:56 AM   #3
Not even engineered hardwood floor?
You mean full plank of wood (oak?) that will fit each stair (wide enough to not have to put 2 per stair?)
Old 01-20-2013, 12:14 PM   #4
funfool's Avatar
Rewards Points: 534
I agree 100% with Joe on this one.
I seen the title of your post and went
I have seen where others have done it, Is just a terrible idea for many reasons.
If a customer wants it, I would simply refuse to do it. Pick another option, or find another carpenter.
Would just whiz me off going through the headache's of making it look nice, all the while knowing was creating a hazard and crappy product.
I vote no also.
funfool is offline   Reply With Quote
Old 01-20-2013, 12:17 PM   #5
OK, fair enough....
So I would need something like that, right?
http://www.homedepot.com/h_d1/N-5yc1...1#BVRRWidgetID
How should I attach it on the current stairs? Glue only, glue + nails where the nail holes will be hidden with matching putty?
Old 01-20-2013, 12:51 PM   #6
funfool's Avatar
Rewards Points: 534
I would use liquid nails, And and nail it with my finish gun using 2 1/2" nails,
That length may be over kill, is simply the size I use most and always carry them in the truck.
Hide the nails where you can, but you cant hide all of them. Depending on depth of the tread, I would want minimum of 2 nails front and rear, mat need a 3rd in the middle.
So would 3 nails for each end, and most likely 3 more in the middle, a total of nine nails with liquid nails underneath. This will assure you do not create a squeaky stair, try to fix any current squeaks with screws or nails, whatever you can do, may not get them all.
For the exposed nails, if you keep your nailing pattern consistent, will be fine.
When you finish the wood, the trick is to apply first coat of finish before filling the nail holes.This is important.
The oak is porous, If you apply a sandable stainable oak wood putty before first coat, will be in the pores around the nail holes, will never get it out and will see every nail hole.
The first coat of finish will fill those pores, now when you putty, will only be the small nail hole, and when you sand the putty and apply the final coats, they will disappear.
I pet if you have 50 holes depending on the amount of treads, you may see 3 or 4, and only you will see them because you know they are there.
But you are on the right path and will build a nice product that will look beautiful and last years.
Old 01-20-2013, 01:13 PM   #7
Rewards Points: 264
I have to agree with the others, use solid wood treads. By the time you buy all of that nosing for each stair, you can spend a little more a do solid wood. If it adjoins a laminate floor, you can stain match oak really easy. If you don't also want to do solid risers, and you are painting these, maybe consider a birch plywood or other paint grade material.
Awoodfloorguy is offline   Reply With Quote
Old 04-01-2013, 05:31 PM   #8
Hi
Redo my stair may be my next job...What nails do you recommend (diameter, size of the head, minimum length)
Old 04-02-2013, 09:47 AM   #9
I use constrution adhesive, and 2-1/2 galvinized finish nails in predrilled pilot holes in the tread.
The reason I use the galvinized nails is there rough so I feel they hold better.
I would not use a finish gun for this one.
Old 04-02-2013, 09:59 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
My in-laws have bamboo laminate on their stairs....it's better than the carpet they used to have....but they now wish they had not done it...
It looks great right after it's done.......
But....
Once you start walking on it....the outside board starts to wobble because it gets the most force of people going up and down....
Yea...don't do it.....you want to use a single piece of hardwood.....
Remember the saying? "You learn by your mistakes"..........why do you think the above guys are so bloody smart?
ddawg16 is online now   Reply With Quote
Old 04-02-2013, 10:20 AM   #11
Laminate was my original idea, but after the answers from Joe and Funfool, i won't go that way but oak treads instead.....
The Following User Says Thank You to french_guy For This Useful Post:
BigJim (04-02-2013)
Old 04-02-2013, 10:35 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 406
Talking about nail sizes, back before nail guns I use 10d finish nails and construction adhesive, I would cut the head off a nail, put it in a drill and drill a hole using the nail. It looks like the hole would be too large drilling that way but it isn't, worked good for me.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-02-2013, 10:44 AM   #13
And why not using a drill bit?
Old 04-02-2013, 11:01 AM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 406
Out on the jobsite sometimes it is hard to find a bit the exact size. Much easier to just use the same size nail you plan to use.
Jim
Old 04-02-2013, 11:57 AM   #15
Rewards Points: 2,238
Don't use laminate flooring on stairs!
It don't work too well!
It can be done - way too much "jumping through hoops", though!
It's also a little, slippery!
Not, what you want on stairs!
"RF"
(Sure - you can use a drill-bit - be prepared to break some, though!)
Like some of the posts above - expansion/contraction!
rossfingal is offline   Reply With Quote
Laminate at base of stairs daisychain Flooring 0 11-29-2010 01:22 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 10:52 PM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 10:12 PM
