Staircase Kickboard Gaps - Flooring - DIY Chatroom Home Improvement Forum
Old 11-27-2015, 12:11 AM   #1
Rewards Points: 18
I recently had my staircase refinished. I painted the kick boards white. Where the kick board meets the stair there are some gaps on a few of the steps. Im guessing its just age and house settling. Is there anything someone would recommend to fill those gaps? I tested a spot with a caulk but with the grain on the wood it doesnt look clean so I quickly cleaned it up before it set.
Any suggestions or is something you just live with
dlam9946 is offline   Reply With Quote
Old 11-27-2015, 01:27 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 5,112
If you use a good putty knife with a good sharp square edge, you can caulk the gap then use the putty knife to clean the caulk off the tread and form a good square edge on the caulk. It looks like the white is just extended on down and it will not be noticeable.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
BigJim is offline   Reply With Quote
Old 11-27-2015, 07:35 AM   #3
Rewards Points: 6,690
Please post a picture.
You only needed enough caulking to fill the gap, not all over the tread or riser.
Tiny hole is the tip, light touch on the handle, wipe down with your finger then wipe again with a damp sponge to remove the excess.
Staircase and stair area renovations chukker Remodeling 25 07-12-2014 09:05 AM
expanding foam for gaps in masonry foundation LMHmedchem Concrete, Stone & Masonry 6 08-22-2012 10:36 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 07:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
