Stair Treads And Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 11:01 PM   #1
Stair treads and concrete floor
Hi all. We have been remodeling and adding a new addition since March. We have stairs and will be using unfinished oak for the treads and risers. Already have our stain picked out, but I'm wondering what I should use to poly them.
Seems like I have seen a poly made specifically for floors, should this be used? Any other suggestion?
Secondly, we are putting in our master bedroom floating hardwood for the floor. This will go over concrete. However, we have in floor heat. What kind of barrier should be used? I was told regular tar paper would be fine, but that seems just way to simple....
Thanks for the info...
Kibby is offline   Reply With Quote
Old 09-05-2011, 06:02 AM   #2
woodman58's Avatar
What ever brand of floor poly you find will do. We all have our prefferances. Mine is Bona. Under the floating floor you need a 6 mil. Plastic available at your home store. Make sure and tape the seams.
woodman58 is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Is covering inside concrete stairs with wood treads cool? HandyBeth Flooring 5 07-03-2011 11:27 AM
How to install granit treads and railing lsyrkin Tiling, ceramics, marble 0 05-08-2011 08:43 PM
How to install granit treads and railing lsyrkin Building & Construction 1 05-08-2011 07:06 PM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 10:37 PM
