Stair Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 07:37 PM   #1
Stair Treads
I am installing Oak stair treads, the bottom two steps are not flat and level. Is it ok to use a premixed leveler and will construction adhesive bond to the leveler or is there a better alternitive
Dan O is offline   Reply With Quote
Old 02-20-2012, 08:21 PM   #2
woodman58's Avatar
Buy a GOOD 1 and 1/2 inch wood chisel and chisel the top of the sringers to level with each other. After doing this you may need to raise the hight of each stringer flat (not angled) shims to keep the hight of the step even with the other steps even.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 02-20-2012, 09:33 PM   #3
Better than buying a chisel, buy a 4 1/2" angle grinder, rubber backer pad, and some 36 grit discs. This tool is like my right arm. I use it for leveling, scribing, coping, etc, etc. In no time flat you can grind to a line you draw on the high stringer. Don't use leveler mix. If a stringer is low, squirt on construction adhesive and embed a shim in the glue, then add more glue on top of that. Stringers are notorious for shrinking after they are cut, leaving the flat area for the treads leaning downhill to the front and the riser leaning to the back at the top. That is the only slack I give a framer. I have spent hours trying to get a set of stringers into specs after a framer has butchered making and installing them. One of my BIG pet peeves!
MNsawyergp is offline   Reply With Quote
Stair treads - wood choice tradeoffs? kidtire Flooring 0 02-01-2012 06:15 PM
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 09:11 AM
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 11:29 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
