Stair Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 11:49 AM   #1
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Stair Treads
How much overhang is normal?
Old 08-31-2011, 12:03 PM   #2
the Musigician
DangerMouse's Avatar
It would seem 1/2" to 1" is the norm.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
jbfan (08-31-2011)
Old 08-31-2011, 10:40 PM   #3
Registered User
Rewards Points: 4,924
There is normal and there is legal.... I'm normally legal but others say I'm not legally normal...what do they know.lol.
R311.7.4.3 Profile.
The radius of curvature at the nosing shall be no greater than 9/16 inch (14 mm). A nosing not less than 3/4 inch (19 mm) but not more than 11/4 inches (32 mm) shall be provided on stairways with solid risers. The greatest nosing projection shall not exceed the smallest nosing projection by more than 3/8 inch (9.5 mm) between two stories, including the nosing at the level of floors and landings. Beveling of nosings shall not exceed 1/2 inch (12.7 mm). Risers shall be vertical or sloped under the tread above from the underside of the nosing above at an angle not more than 30 degrees (0.51 rad) from the vertical. Open risers are permitted, provided that the opening between treads does not permit the passage of a 4-inch diameter (102 mm) sphere.
Exceptions:
1. A nosing is not required where the tread depth is a minimum of 11 inches (279 mm).
2. The opening between adjacent treads is not limited on stairs with a total rise of 30 inches (762 mm) or less.
http://publicecodes.citation.com/ico...011_par012.htm
Gary
Old 09-01-2011, 06:29 AM   #4
the Musigician
So... in layman's terms? How much overhang is normal? 1/2"? 1"?
DM
Old 09-01-2011, 07:22 PM   #5
Registered User
Code says 3/4" to 1-1/4", above. I installed 1-1/4" for over 30 years of stairs, maybe twice only with less. Tread was usually 10". Makes a very comfortable step (ergonomic) with a 7-1/2 (+ -) riser..
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (09-01-2011)
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 11:29 AM
replacing stair treads graeserhp Carpentry 15 04-01-2011 07:22 PM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 08:13 PM
