Stair Threads, Or Nosing For Curved Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 01:27 PM   #1
Stair Threads, or nosing for curved stairs
Hi
I'm trying to figure out a way to put laminate on curved stairs.Picture
Does anyone has an idea how I could do this? (custom stair threads, or nosing etc)
Your input will be highly appreciated.
DarkLight is offline   Reply With Quote
Old 07-26-2012, 02:57 PM   #2
Rewards Points: 260
I might consider doing solid hardwood and stain it to match the laminate you are putting in. Laminate only comes in a few varieties of moldings so it would be nearly impossible to make it look good on these steps.
Here is how I would do it;
Make stair nosings myself out of really wide pieces of oak. I would cut the radius on them and then router a rounded edge onto these pieces.
Then I would get some thin oak plywood and cut it into strips for the risers. These are bendable and would make installing these easy.
Install the risers first, then the nosings, then fill in the rest with wood flooring. Then stain to match the laminate you have and finish them with a polyurethane.
The only option I really see aside from this is to rebuild the stairs to make them square.
Awoodfloorguy is offline   Reply With Quote
Metal Stair Nosing Over Laminate? mrlang02 Flooring 6 05-21-2012 06:02 PM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
floating engineered floor perpendicular to stair nosing Rad111 Carpentry 5 02-27-2011 03:48 PM
Stair building - Traditional stringers or EZ Stairs? dwoloz Carpentry 12 08-24-2010 10:26 AM
ceramic tile stairs with wood nosing karenk Flooring 0 03-17-2010 11:30 PM
