Stair Stringer Capacity For Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 06:36 AM   #1
Rewards Points: 324
Stair Stringer capacity for tile?
Looking to stone tile my stairs. Should I have any concerns of weight of stone tile on them? What would stringer requirements need to be for stone tile?
tigerbalm2424 is offline   Reply With Quote
Old 06-24-2008, 07:55 AM   #2
Registered User
Termite's Avatar
To install tile of any kind on stairs, you need the stairs to be stiff. If they have any deflection in them, the grout joints won't survive long. The weight of the stone will contribute, but won't be as big of a factor because it is a static load on the stairs at all times and doesn't cause movement of the whole system. A dynamic load...Someone walking up and down the stairs, will be the real issue.
Do you have access to the underside of the stairs? There isn't a given stair jack requirement because there are just way too many variables (stair seat cut dimensions, jack material, length, etc.). If you have access to the underside of the stairs perhaps a wall could be built underneath the jacks (perpindicular to them) to keep them from deflecting.
If you're re-building the stairs altogether, I'd suggest 11-7/8" LVLs for jack material. TJI Timberstrand rim board can also be used for stair jacks, and it is nice and stiff. Both products have excellent dimensional stability. If your stairs are three feet wide, I'd use three jacks.
Old 06-24-2008, 08:01 AM   #3
Rewards Points: 324
Yes, I have access to the underside of the stairs, no issue there. The original builder cheaped a lot of the materials initially so the plan is to start by removing the carpet and see what I am dealing with, and go from there. Im sure there will be some replacing/adding going on. What about adding stringers? If there are 3 and I add two more in between them....
Also, what are stair jacks/jack material?
Old 06-24-2008, 09:59 AM   #4
47_47's Avatar
Rewards Points: 58
I'd say the jacks another name for the stringers, based on thekctermite's recommendation to use LVL and a kneewall supporting them.
47_47 is offline   Reply With Quote
Old 06-24-2008, 10:21 AM   #5
Registered User
Termite's Avatar
Yup, those words get used interchangeably around here. Sorry to confuse things!
Old 06-24-2008, 10:28 AM   #6
Rewards Points: 324
ok, if thats the case then adding two more stringers should be adequate right?
repairing stair with missing riser? darsunt Building & Construction 3 06-18-2008 10:51 AM
Holes in stair stringers wfischer Building & Construction 15 03-09-2008 09:21 AM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
Stair question crapenter25 Carpentry 5 09-21-2007 11:07 PM
who has "nice" stair edging? mattroos Flooring 8 09-07-2007 10:34 AM
