Stair Steps - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2015, 08:39 AM   #1
Rewards Points: 72
Stair steps
Move-If in the wring place.
Originally I was going to use treated lumber for my stair steps.
Is there a better choice ?
Blessings
williamlayton is online now   Reply With Quote
Old 03-02-2015, 09:30 AM   #2
Rewards Points: 1,754
Stair steps
Yes the pressure treated will work.
What's the reasoning for the skirts behind the stringers?
That's going to cause water to lay between the two pieces and rot out the ends of the treads.
You also need another stringer in the middle.
What's at the top of that stairway, a door?
If so there needed to be a landing before the stairs.
How do you get from the stairs to the deck?
Old 03-02-2015, 11:52 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 3,482
Stair steps
Looks good but like Joe said, I would get rid of the two outside skirts. I see you do have a center stringer already cut and the landing at the top of the stairs looks good also. I would suggest that you put a support under the stringers half way up though. Other than that it looks like you are good to go.
New members: Please consider adding your location to your profile.
If you aim at nothing, you will hit it every time!
Jim
BigJim is online now   Reply With Quote
Old 03-02-2015, 12:16 PM   #4
Rewards Points: 72
Stair steps
I am not concerned by the water laying between the stingers--caulking and glue will handle those concerns.
The outside is just for extra strength--keeps the trambolin effect out of the build. They are glued and screwed.
The stringer you see is a mis-cut. width of the stairs does not dictate a third stringer, but I plan on blocking under each step.
The stairs end on a landing--see pics.
I am considering open metal treads.
Blessings
how do i finish drywall on my stair steps elkhunter Drywall & Plaster 3 09-11-2011 06:08 PM
Stair Steps Question jeff9353 Remodeling 8 02-15-2010 10:04 AM
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 07:21 AM
concrete stair with wooden steps totogamez General DIY Discussions 2 03-05-2009 09:30 AM
What type of wood to replace stair steps? darsunt Building & Construction 7 04-30-2008 01:22 PM
