Stair Risers - Flooring - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 07:05 PM   #1
Rewards Points: 27
Stair Risers
Hey guys i am about to redo my stairs and am going to use red oak stair treads and stain them. my issue is with the risers, i want to paint them white and was wondering what other wood can i use as to cut cost. since i want to paint them i dont want to spend on a good type of wood just to cover it. any suggestions welcome
woodenSpoon is offline   Reply With Quote
Old 11-10-2011, 07:27 PM   #2
If covering existing riser. Use underlayment such as Ultraply. 1/4 inch thick 5 ply birch. Primer before painting. Ultraply is a good solid underlayment with a lifetime warranty.
plowboy is offline   Reply With Quote
Old 11-10-2011, 07:53 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
If you are installing new risers you can use 3/4 inch plywood or Poplar, I don't like using pine as some pines don't hold the paint well because of the resin. On the plywood, if you plant to use it, I would go with a Birch as it will paint well and look good.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
interior stair risers pushed in davesink Carpentry 2 09-27-2011 03:25 PM
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 08:38 AM
Lighting for stair risers jweiner Electrical 2 04-06-2009 05:18 AM
Tiled Stair Risers kcdave Carpentry 2 02-22-2008 08:12 PM
3/4" birch ply for stair risers? ACobra289 General DIY Discussions 4 12-15-2007 06:17 AM
