Stains On Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-21-2006, 02:49 PM   #1
VHI
Stains on Carpet
I have a light colored carpet with stains(grease,dirt,soda stains). I am going to make an attempt to steam clean it, but first i am looking for any suggestions on what works best. carpet is tan in color.
VHI is offline   Reply With Quote
Old 12-25-2006, 09:45 PM   #2
remodeling pro
I have used a dry powder system made by Oreck(the vacuum cleaner people) and have always been amazed at how well it works.
troubleseeker is offline   Reply With Quote
Old 12-27-2006, 12:40 PM   #3
Floorwizard's Avatar
check your local flooring store for MAINTAIN or CAPTURE cleaners.
works very well.
Floorwizard is offline   Reply With Quote
Old 05-18-2008, 08:03 PM   #4
carpet stains
Try a mixture of 50 per cent amonia and 50 percent water. First test it on an inconspicous spot to make sure it doesn't fade the carper. This is a cheap solution to a lot of stain problems.
cramer is offline   Reply With Quote
Old 05-19-2008, 01:30 PM   #5
ayeshaa's Avatar
For grease stains, dab with a small amount of dry-cleaning fluid. Then, blot with a small amount of dishwashing liqiud and warm water. Blot from the outside in, and let stand for five minutes
Place paper towels over the stain and let dry, overnight if you have to.
Brush clean and vacuum once the stain is dry. The flat brush should pick up and dried particles that are lingering, and the vacuum will do the rest.
ayeshaa is offline   Reply With Quote
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
Cleaning Pet Stains From Carpet KHooper General DIY Discussions 3 02-23-2005 06:52 PM
