Staining A Design Into Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:29 PM   #1
staining a design into hardwood
after finishing the bedroom hardwood (red oak) we will be continuing down the stairs trhou the living/dining area..
I had this crazy idea to do a design on the stair first landing with stain.. like a moasic star or maybe celtic pattern along the perimiter...
but without cutting up the floor and replacing it with stock ..
i was thinking after i had the floor sanded to bare wood.. tape off with some frog tape stain the floor as normal.. let that dry then lightly scroe the floor around the tape, retape on the outside of the lines.. then fill in the unstained area with the accent stain let dry and poly over the whole sha-bang..
anyone try this? have nay advice?
thanks!
jarheadoo7 is offline   Reply With Quote
Old 07-27-2011, 12:37 PM   #2
Rewards Points: 5,336
Stain isn't like paint as it absorbs into the wood. It will bleed under the tape. If you want a design, inlay it.
Ron
B. Franklin 1759
Old 07-27-2011, 12:38 PM   #3
AGWhitehouse's Avatar
I second the bleeding under tape...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-27-2011, 01:10 PM   #4
Rewards Points: 252
Agreed, stain would bleed, but maybe you could try this with shellac? Shellac the entire step, tape, carefully shellac your pattern (too much rubbing would mix the two shellacs and probably cause bleeding), and coat with poly. What might be easier is to paint your pattern, shellac everything, then poly everything.
shazapple is offline   Reply With Quote
Old 07-27-2011, 01:29 PM   #5
the Musigician
DangerMouse's Avatar
weeeeellllllll, not necessarily..... In my DM creations thread I show a guitar that I taped off custom stencils of leaves and (air-brush) SPRAYED stain to color them. Darker around the edges and lighter in the middles. It worked perfectly and did not bleed at all.
DM
Old 07-27-2011, 03:51 PM   #6
DM
weeeeellll, you make a good point. Airbrushing applies very little stain at a time and the bleed will be greatly minimized. I think our "bleeding" comments stem from the use of a brush or foam pad for an applicator.
Old 07-27-2011, 03:56 PM   #7
the Musigician
Yup, THAT would bleed all over the place, for sure.
They make spray cans that you pressurize yourself with air from a bike pump that would work very well in this application.
DM
Old 07-27-2011, 04:00 PM   #8
DM
Then the Op can practice on scrap wood with that to see if it will do the job.
Ron
B. Franklin 1759
Old 07-28-2011, 06:27 AM   #9
i have seen the air cans before.. i might pick one up and give it a shot..
i heard about the shellac being a good way to keep everything from running into each other as well... maybe if i airbrush the colors, shellac between colors and then poly the whole mess and sand it down to even out the different levels.. it might turn out ok!
thanks for the info gang.. were still finishing the kitchen before we get to the floors but if all goes well i will update
Old 07-28-2011, 06:39 AM   #10
the Musigician
Once you shellac, stain won't take.
DM
Old 07-28-2011, 07:00 AM   #11
Rewards Points: 252
I thought of shellac because you can mix an 'Aniline Dye' to change the shellac to whichever colour you wish.
Old 07-29-2011, 08:03 AM   #12
DM
if i lightly score the wood at the stain lines would that prevent the color from blending?
Old 07-29-2011, 08:51 AM   #13
No it won't. But it will present an area where the stain will overly darken.
A simple experiment on a scrap piece of wood will show you what happens.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
DangerMouse (07-29-2011)
Question about staining hardwood. Scotch Flooring 4 03-10-2011 07:47 AM
Staining Hardwood Alcarte Flooring 4 02-02-2011 08:37 PM
Is staining hardwood floors the best way for me to go? AndreaMB1978 Flooring 7 07-27-2009 02:08 PM
Questions on Staining Hardwood! noodlesalad Flooring 2 12-15-2006 09:17 AM
Staining hardwood floor noodlesalad Flooring 4 05-29-2006 08:13 AM
