Staining Ceramic Floor Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 11:16 PM   #1
Staining ceramic floor tile
I have probably the original ceramic floor tile, 1995. It's not that the tile looks bad but the grout does. I had it professionally cleaned last yr (arm & a leg). So since my tile is not smooth, I would like to stain it and seal it. I'm thinking, if I stain it, the darker color will go in to the divits and grout and then I could seal it. Otherwise, the way it is, the divits collect the dirt and the grout is really dark in the heavy traffic areas and lighter in the low traffic areas. So, can I use a stain on the tile and grout? Wipe off the extra, hoping the grout will absorb the stain and the divits in the tile will 'puddle' and once dried, look good and be able to seal. So....can I do this? Can I use a regular wood stain? Any special products needed? Any help is greatly appreciated! Lind
MrsRRP123 is offline   Reply With Quote
Old 06-16-2012, 01:07 AM   #2
Renovations contractor
Bonzai's Avatar
Grout needs to be sealed so that it does not discolour or let water penetrate. Did the person who cleaned it also reseal it afterwards? If the grout is 17 yrs old then it should have been resealed a few times already.
You cannot stain glazed ceramic tile as it is non-porous. With pitted older style tiles they just need to be cleaned regularly. You could apply an epoxy flooring product over the whole floor but that may be a bit too industrial looking depending on the style of house.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
staining ceramic tile floor bjv268 Flooring 0 09-26-2010 09:22 AM
Ceramic Tile Staining Over Radiant Floor Heating?! rcuerrier Flooring 3 04-25-2010 09:42 AM
