Stained Vs. Polished Concrete? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 10:56 PM   #1
Rewards Points: 18
Stained vs. Polished concrete?
I am refinishing the floor of the lower level of our 1960 split level home. It is on a slab, and we have removed all flooring down to the slab. We would like to have the concrete remain as the flooring, and are planning to have it either polished or stained - and dyed in both cases.
I would like to know if one might look better in a residential setting, or if this is purely individual opinion?
My understanding is the that in polishing, they use increasingly fine grit grinders, up to 1500 or 3000 grit, then seal.
In staining, the grinding stops at about 50 or 100 grit, and then they use acrylic or wax, with a number of layers of wax. The result is less shiny/industrial, and maybe more rustic - but requires a little more upkeep.
I would appreciate any insights or experiences anyone may have. Thank you!
rumiat is offline   Reply With Quote
Tags
concrete , polished , polishing , stain , stained
Has anyone stained concrete to look more like ashpalt? CoconutPete General DIY Discussions 10 01-14-2012 08:33 AM
Stained Concrete Floors WirelessG Flooring 12 11-17-2010 12:18 AM
Stained concrete floor showing water leak Rox Plumbing 0 09-27-2010 04:33 PM
Reasons for stained fresh concrete stadry Building & Construction 3 08-20-2010 11:04 PM
Anyone have stained concrete inside their home? wysteria Flooring 2 12-02-2009 05:11 AM
