Stained Marble Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 06:18 AM   #1
Hey...I am a newbie....I would appreciate if I get a solution of my problem...My problem is... how can I prevent the marble floor from getting damaged...
tweety00 is offline   Reply With Quote
Old 10-08-2010, 07:02 AM   #2
I suggest that use only warm water and a soft mop. Beware of any type of mop that has the potential to scratch; marble is very susceptible to scratches due to its soft nature.
Turbo56 is offline   Reply With Quote
Old 10-08-2010, 06:46 PM   #3
also really easy to polish out
i've had marble in both my bathrooms for a couple years now. no stains, no problems and scratches can buff out if you need to. i honestly beat the hell out of them. work boots, dropping crap, mud, grime, you name it. they clean up just fine. i would use a good sealer and keep up on it though. think i used 511 if i remember right.
the single most damaging them you can do is drop a blunt object. a screwdriver, hair clippers that land on the steel side. things of that nature will chip the stone.
racebum is offline   Reply With Quote
Old 10-08-2010, 07:45 PM   #4
Seal it??
wnabcptrNH is offline   Reply With Quote
Old 10-08-2010, 07:46 PM   #5
yes marble is a pours stone and isn't hard to stain if you don't seal it
Stained Concrete Floors WirelessG Flooring 12 11-16-2010 11:18 PM
cleaner for acid stained floors? INKlusions Flooring 3 03-17-2010 07:36 AM
Just bought a house with Travertine floors. Can the marble be refinished? Cost? Waterfowler Flooring 17 09-22-2009 02:00 AM
marble floors hohmannranch Tiling, ceramics, marble 11 11-09-2008 02:12 AM
black areas in stained concrete floors? kaala Flooring 2 05-01-2008 12:50 PM
