Old 02-19-2007, 11:49 AM   #1
Angry
Stained Concrete Floor Finish
About 3 years ago, we had carpet removed and textured concrete applied and stained. I hate it. Even though we knew the contractor personally, he won't return calls now that we have some questions and problems. There is fading and total color disappearance in high use areas. The cement is cracking. The texture is uneven and therefore so it the color.
What options are there to remedy the situation?
I'm not opposed to doing something different with the existing flooring and color. Can it be ground down [hopefully while wet to hold down the dust] and re-stained?
Can a 'skim' coat be put over it to smooth it out and apply laminate?
Is there some sort of underlayment that can be put down and then apply laminate without adding more cement?
shapeshifter is offline   Reply With Quote
Old 02-19-2007, 01:07 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sounds like a post question for "ConcreteMasonry"....
- Build Well -
Old 02-19-2007, 05:27 PM   #3
Question
Hmmm, Atlantic would you happen to have the web address for that topic?
Old 02-19-2007, 06:26 PM   #4
'Concretemasonry' is a poster on this forum....Very knowledgable in regards to anything concrete.....
- Build Well -
Old 02-19-2007, 07:26 PM   #5
Thanks, I emailed him off-line.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
