Old 05-20-2012, 09:24 AM   #1
Stained concrete
Want to stain my Floors but I have old tile and black adhesive under my carpet. What is the easiest way to remove the adhesive to get a clean floor to stain? Would I be able to put a concrete overlay over the adhesive? I was told it wouldn't work because the overlay won't stick to the adhesive. Suggestions please!
kataylor is offline   Reply With Quote
Old 05-20-2012, 09:31 AM   #2
Stained concrete
Your going to have to go to plan B on this one.
To stain a concrete floor it has to be perfectly clean, with nothing in the pores of the concrete. Not even paint can be applyed over the old glue.
Old 05-20-2012, 09:51 AM   #3
Ravenworks's Avatar
Stained concrete
Surface grind the floor.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-20-2012, 09:56 AM   #4
Stained concrete
Would I have to get the adhesive off before I can put the overlay down? Do you have any suggestions on What to use to get the adhesive off?
Old 05-20-2012, 10:05 AM   #5
Stained concrete
Will surface grinding get the adhesive out of the pores? Would it be the easiest thing to do?
Old 05-20-2012, 10:51 AM   #6
Stained concrete
http://kemikostainforconcrete.com/application_info.html
kataylor (05-20-2012)
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 01:34 PM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 04:27 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Mulch dye stained concrete. EPERRINGTON Landscaping & Lawn Care 1 04-21-2011 09:57 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
