Stain Concrete Floor Or Do Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 08:00 AM   #1
Stain concrete floor or do laminate?
I was wondering if someone could provide advice on whether it is better to stain my concrete floor or do a laminate flooring?
It is a slab foundation at grade, new construction. The area that we'd be flooring is about 20' x 22'. I'd prefer to stain it but the reason I was shying away from staining it is most reviews of items at the big box stores were pretty bad - Does anyone have a product they can recommend?
Thanks!
Henry
PennJersey is offline   Reply With Quote
Old 03-13-2011, 08:03 AM   #2
Rewards Points: 14
How long ago was the concrete poured stain will not take right if it is all the way cured.
flynavy is offline   Reply With Quote
Old 03-13-2011, 08:56 AM   #3
Poured the end of November.
Thanks,
Henry
Old 03-13-2011, 09:59 AM   #4
Rewards Points: 14
you can always cover the stain concrete if you do not like it but since it is poured pretty recent you should still be able to stain it I did a outside patio with the box store stain and a bug sprayer it worked and looked great my concrete was only 3 weeks old when I did it. I will look today to see what brand I used.
Old 03-13-2011, 10:01 AM   #5
Rewards Points: 200
What is the room to be used as ?
A floating engineered would be cheaper and give more warmth .
I would defiantly have CC Tests done for moisture .
Floor Doc is offline   Reply With Quote
Old 03-13-2011, 03:06 PM   #6
It is going to be a tv/entertaining room.
Old 03-13-2011, 03:40 PM   #7
Rewards Points: 200
I don't want to talk you out of a floor you have your heart set on , but my preference would be wood . stay away from LL and big box stores .
If you like i can do a on site inspection for you and the cc tests .
Tags
laminate flooring , staining concrete
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Install swiftlock plus laminate flooring on a concrete basement Rdavoodi Flooring 1 10-13-2011 03:00 PM
Uneven Concrete and Laminate Kab Flooring 4 12-24-2008 08:01 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
Concrete Pavers and Stain terryhflyer Flooring 2 06-04-2008 04:59 PM
