Old 06-19-2009, 11:24 AM   #1
2 fingered typer
woodnthings's Avatar
Question
Squeaky subfloor TandG joint
After removing the carpet and pad I am going to use self stick tile on the 3/4 ply T&G subfloor. There are numerous nails 6 " apart, no.8's. I screwed in about 10 deck screws near the squeak and countersunk. Still squeaks! Finally I realized I think it's in the joint. My solution is to make a saw cut down to the tongue to open the joint and then put epoxy down into the joint. The subfloor was glued to the joists, but not in the T&G joints...darn! Looking for a "better" idea besides talcum powder! Thanks, bill
woodnthings is offline   Reply With Quote
Old 06-19-2009, 04:25 PM   #2
Tileguy
Bud Cline's Avatar
Graphite.
You are proposing way too much work to fix that squeak. Lubricate it and be done with it.
Old 06-20-2009, 02:02 PM   #3
2 fingered typer
Lightbulb
The minute I made the thin kerf cut the squeak disappeared. I filled the joint with Durhams wood putty, sanded it all smooth. Good to go....I think!
bill
Old 06-20-2009, 03:06 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Why are you using peel and stick? They won't last.
Old 06-20-2009, 04:57 PM   #5
2 fingered typer
All the rest of my vinyl tile was applied with mastic/adhesive. I just used the peel and stick at a remodel/ rental house, but "won't last" wasn't on my mind for that unit. They do look great and were a cinch to install, once I figured out the goofy pattern. You don't recommend them, I guess?
I'm 67 yrs old how long would I have before ripping them out? What is the main problem adhesive failure? Thanks for the info. bill
Old 06-20-2009, 05:22 PM   #6
If they get wet they won't stay down. They are also not durable, but I can see using them in a rental.
Old 06-20-2009, 05:29 PM   #7
Tileguy
Bud Cline's Avatar
They also slide and relocate themselves under the pressure of furniture legs and ladders and such.
Old 06-20-2009, 06:42 PM   #8
I thought the rule was "no advertising". Thank you for removing the ad.
Old 06-20-2009, 06:53 PM   #9
2 fingered typer
From setting the straight edge, adjusting the saw depth, mixing the Durhams. Waiting 1 hr for it to harden (not counted as repair time), belt sanding the whole floor about 15 mins. (5'x6' area not counted as repair time). Floor is prepped for sealant and tile. The squeak was the T&G plywood shifting in the joint between the joists as you stood in between. A from the top repair. bill
I thought so as well. From a 1 post guy, too. Probably a rule has been broken here.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Can't get ball joint to separate from knuckle on '88 R10 1/2 ton 2WD Suburban TJMS81 Automotive Repairs 11 11-27-2009 11:11 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 09:10 PM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 12:56 PM
